Silverado DIY and Useful Threads This section is for Do-It-Yourself articles and other informative FAQ threads. If you would like to submit an article, contact a member of staff!
Starter issues.
Old Nov 29, 2021 | 2:19 PM
Greylio's Avatar
Default Starter issues.
I had a 99 350 5.7 who keeps eating starters. I replaced the flywheel with a new one. Still keeps eating them. Not sure what to do next. We have used shims and the bolts are tight. Using starter bolts brand new. This truck needs to be my daily driver again and starters are getting expensive.
Old Nov 29, 2021 | 2:49 PM
Welcome from Florida. What is going bad on the starter? Is it eating up the gear or is it an electrical problem with the starters?
Old Nov 29, 2021 | 5:58 PM
kevinkpk's Avatar
Pull the housing away from the flywheel. With a screwdriver or pry bar engage the starter bendix. Check the mesh on the fly wheel to starter. Go from there.
Old Nov 29, 2021 | 9:49 PM
Greylio's Avatar
It seems to be the mechanical side. Not electrical. It starts making a grinding noise when trying to turn the truck over after a few times doing this the starter is done.
Old Nov 30, 2021 | 10:23 AM
Are you sure that you are getting the correct starter? Did you replace the flywheel before this trouble started or after?
Old Nov 30, 2021 | 10:59 AM
Greylio's Avatar
The flywheel was replaced after going through 3 starters. I have tried both starters that will fit my year truck. Both have the same issue. Unless there is a third option that I don’t know about.
Old Nov 30, 2021 | 1:36 PM
If you still have the original starter, I would have that rebuilt and see if that works. There are starters for those years that have 9 teeth and 11 teeth. Have you tried them both?
Old Nov 30, 2021 | 2:05 PM
Rednucleus's Avatar
Did you replace your 1st starter because of the same problem? I assume stock motor/transmission. Was the original flywheel damaged, and did the new one look identical?
Old Nov 30, 2021 | 2:09 PM
Greylio's Avatar
I don’t have the original starter. That went out in 2010. Lol. Stock motor and transmission. The fly wheel was replaced after the 3 rd starter died.I don’t know the number of teeth on them.
Old Nov 30, 2021 | 4:49 PM
Rednucleus's Avatar
How long did it take to go through 3 starters? Did the flywheel show visible damage to the teeth?
