02 Silverado Trans
02 Silverado Trans
I just changed the trans oil in my 02 1500 Silverado. I just checked the level and it is about 1-2 quarts high.
Will this cause a problem ?? What are the symptons I should look for.
Thanks, Alan
Thanks, Alan
I believe that it could cause a serious problem - related to pressure or "foaming" of the fluid; but your best bet is to ask a professional mechanic or transmission shop for advice.
Depending upon the capacity of your transmission, 1 or 2 quarts might not matter much.
Fluid Level
If you put the correct amount of fluid in during filter change you should be O K but make sure you check oil on level ground, engine running and warmed up and in park. If level is still high I'd drain some until fluid level is in the proper marks on the stick.
None the wiser, I made the mistake of not measuring how much came out when I drain the fluid to drop the pan in order to replace the gasket and filter.
How much you put is very important. Too much is just as bad as too little. If you have put too much, it may even leak the access fluid out but typically your gears may slip.
Mine was only about a pint too much but even then, especially the reverse was slipping a bit, late to engage and acting all erratic. I thought my tranny was somehow damaged, possibly the sun belt got burnt, etc. I live in a very uneven area so it was hard to find a perfectly leveled place but when I did, I discovered that it was too much. Using type suction tool, I sucked out the excess from the dipstick hole. That was much easier, faster and cleaner, not to mention the fact that I was sucking out 4floz. at-a-time which allowed a more controlled process.
Anyhow, like others mentioned, make sure your vehicle is parked on a level ground using one of those cheap cross-check level tool (with the bubble).
The vehicle should always be on a level ground when checking any kind of fluid levels (duh, huh?). For tranny fluid, make sure your car has warmed up already (idled for minimum 5 minutes):
- Shift through each gears while waiting about 5 seconds in each gear
- Put it in Park
- While the vehicle is still running (idling)
- Pop the hood and check the tranny level using the dipstick, you might have to clean the stick the first time, put it all the way back in for a few seconds then pull it out to check.
IF it is indeed too high (even a 1/8" above full line), leave the stick out and turn off the engine.
Using a suction tool and a 4'-7' clear hose, suck about 2-3 floz first (container the suction tool come with typically hold about 4lfoz.)
- Afterward, start the vehicle and check the level again.
- Repeat the process if you need more out but if you suck out 2floz at-a-time you, the process will be much more precise.
Remember, as long as the level is between FULL and LOW, it is good!
- Put it in Park
ukrkoz
Silverado & Fullsize Pick-ups
March 4th, 2012 3:16 PM
bouttree
October 3rd, 2009 9:02 PM
monteman85
February 17th, 2009 5:05 PM
sixpack_sid
June 24th, 2008 10:06 PM
