Notices
07 silverado tire question.
Old February 18th, 2008, 9:25 AM
ChevyGuy31189's Avatar
Default 07 silverado tire question.
Whats the biggest tire I can put on a 2007 crew cab silverado 1500 without rubbing? and a 2' leveling kit
Old February 18th, 2008, 9:46 AM
Default RE: 07 silverado tire question.
anyone?
Old February 18th, 2008, 10:15 AM
Judge Z's Avatar
I´ll put 33x11.5R 18 ( 285 / 65 R 18 ) BFGAT KO on 18" Eagle rims
on (my incoming) ´08 2500 HD.
Also with 2" levelling kit.
Dealer said it should work properly. Don´t know, will see
Truck, tires and rims are on the way from States to me to Germany.
northey87's Avatar
Welcome to the forum!!! You got to give us some time to answer your questions. I don't the answer to your question, but someone here will, you just got to give them time.
Old February 21st, 2008, 2:52 PM
ax7221's Avatar
Im not completely 100% sure, but the suggested size for aftermarket tires range from 30-31, when I spoke with my brother, whos a tech at a dealership he said you'll reach the limit on speedo and odometer reading before fitment. Meaning, if you get a tire that BARELY clears everything, you will need to get an aftermarket programmer to bypass GM's max. tire size so the speedometer and odometer will work properly.
Old February 21st, 2008, 5:26 PM
Mcguinness's Avatar
without doing anything you can generally go up two sizes.
Old February 21st, 2008, 11:24 PM
cdusthockey's Avatar
buddy has an 07 and hes running 33 Dick Cepeks with no rubbing, but i dont know if id go any bigger
Old February 22nd, 2008, 1:26 PM
ehhget's Avatar
I have an 01 w/ a 4" suspension lift - my tires are 33's and have good clearance but without the lift would be to big, not sure if the 2" leveling kit would get you there?
If you go to bf goodrich or goodyears site there are chart with diameters of all the tire sizes. I would put the leveling kit in then do some measuring, just keep in mind when you turn your wheels in the front- that is whereit will be tightest.
Old February 22nd, 2008, 3:10 PM
Jeckel707's Avatar
Hey ChevyGuy31189, what brand of spacers did you get?I have been looking for a good brand and i was curious about the install, type of product and how well it is working for you? Is yours the new body style?
Old February 23rd, 2008, 9:16 AM
Mcguinness's Avatar
Get a 6 inch suspension lift and you will have loads of options plus it will look great
tonymacias
Suspension & Tire
August 21st, 2012 9:50 PM
lauraherota
Equinox
October 19th, 2011 9:04 AM
PostRelease
October 8th, 2010 3:01 PM
PostRelease
bamafutbal
July 29th, 2010 9:24 PM
Quick Reply: 07 silverado tire question.
Top
Follow Us
