Notices
Sponsored by: DashLynx
1990 C1500 LO3 motor right turn hesitation
Old August 16th, 2009, 12:07 AM
T_D_H's Avatar
Default 1990 C1500 LO3 motor right turn hesitation
I just bought this truck used, havent done much to the motor, It has cheap headers, new exhaust, new cap and rotor, havent done plugs and wires, cleaned out the throttle body a bit. When I make hard right turns(nothing real hard but aggressive for instance) the motor will almost sound as if it just stops recieving fuel or like the gas pedal was let right off then all of a sudden it will get power again, and depending on the length of the turn will continue to do so untill I either let off or lessen the turn. this happens even when the gas tank is full so it really confuses me. No idea what to even look at and I dont get a check engine light or anything so i couldnt know. Looking for some wisdom
Thanks you
P.S.
MY FIRST POST!
Old August 16th, 2009, 2:07 AM
suzuki-guy's Avatar
That is really weird?#$%? Could it be a faulty powersteering pump drawing to much power from the engine? What about at idel if you turn your wheel all the way does it bog down or only when moving?
Old August 16th, 2009, 10:03 AM
therewolf's Avatar
Hi T_D_H,
A hearty welcome to the Chevy forums! It seems I've seen this topic mentioned a few times, try a thread search here in the Silverado section.
Old August 16th, 2009, 11:58 AM
T_D_H's Avatar
I dont have the slightest clue as what I would search for as I dont even know what to call the problem let alone know what is it lol
Old August 17th, 2009, 8:21 PM
T_D_H's Avatar
any one willing to atleast help me search? or shall i just start going through every thread?
Old August 17th, 2009, 8:22 PM
T_D_H's Avatar
the engine only does it during hard right cornering, not under any other circumstance, ive checked
Old August 17th, 2009, 10:07 PM
Speedy650's Avatar
ive noticed this in my 90 k1500. when im taking a somewhat hard left turn and try to gun it a little it hesitates for a second then kicks in. i havnt really looked into it yet. maybe something to do with the pully?
Old August 29th, 2009, 2:41 PM
T_D_H's Avatar
is it possible for the power steering pump to some how create some sort of voltage spike or something to cause this? if anyone has come across this let me know
Old September 28th, 2009, 3:59 PM
T_D_H's Avatar
well i some what fixed my issue, but it seems it was only temporary. rotor and cap were burnt out and that was causing my issues, I just replaced both with bosch cap and rotor, and it cleared it right up, but now its coming back again and if its the rotor and cap, what would be causing me to burn them out in record time? I have new plugs and wires, both bosch as well since crappy tire wouldnt stock anything ac delco for my truck for over 2 weeks. do I need a new distributor or what? stumped again.
Rupesy
April 28th, 2013 8:48 PM
wa1500
February 26th, 2012 2:33 PM
trrrroy
February 18th, 2010 11:38 AM
T_D_H
August 19th, 2009 9:58 PM
DarkAsylum
November 20th, 2006 11:05 AM
Quick Reply: 1990 C1500 LO3 motor right turn hesitation
