1998 5.7L Vortec-internal coolant leak into oil
Old Feb 17, 2014 | 8:14 PM
jimbo06's Avatar
Default 1998 5.7L Vortec-internal coolant leak into oil
I guess I have a pretty common problem with this engine, coolant leaking into the oil. Is there any way to tell if the cause is a head gasket vs. an intake gasket? A coolant stop-leak will usually fix the problem for up to six months or so, then it reappears. It's time to address the problem. Thanks for your help.
Old Feb 17, 2014 | 10:30 PM
Richardx2's Avatar
Do a coolant pressure check and a compression check of the cylinders. If the coolant test loses pressure there is probably a loss of coolant from the intake. If the coolant pressure test is good and you have a substantial difference during the compression check of the cylinders then you have a head gasket leak. Is there a white milky substance in the oil? My first impression is a leaking intake gasket. Just replaced my intake due to a leaking gasket, but it was an external leak not internal.
Old Feb 18, 2014 | 9:18 AM
jimbo06's Avatar
Thanks for the reply Richard. Definitely coolant in the oil, when I drained the oil it was the color of chocolate milk and the consistency of think paint.
dlaroche
Oct 29, 2014 7:17 PM
Eric Sherden
Sep 24, 2013 1:21 PM
acortez
Jan 12, 2013 6:42 AM
burntpowder
Colorado
Dec 26, 2008 7:32 PM
