2002 hd 2500
2002 hd 2500
Throwing mass airflow sencer code replaced it twice it has a lack of power under 3000 rpm's i changed plugs wires t.p.s fuel pump was replaced about 2 years ago truck has 130,000 on it any idea's thanks
Welcome to the forum...
Keep in mind when a code sets its not always what the problem is, its what the system thinks the problem is....
Check the entire air intake for any blockage or cracks in the air intake after the MAF sensor....
Also check your fuel pressure to be sure its good.
Have you done any mods to the vehicle that may be preventing the vehicle from breathing good or contaminating the MAF like an over oiled K&N filter..
thanks
i sprayed either all around the manifold and no change in idle clean stock air cleaner i need to check fuel pressure i will have to take it to a shop for that .
thanks again
thanks again
heybuddysweetbowtie
Silverado & Fullsize Pick-ups
November 5th, 2021 5:42 PM
Cheesehead
September 5th, 2014 9:22 PM
