79 K5 brake light issues
there is a switch ( more like a button) that your brake pedal pushes when its up to turn off the lights, it right under the dash at the top of the pedal.
alot of times the threads that hold it in place wear out because theyre plastic and it will slip back through the hole not allowing the pedal arm to touch it, or the pedal bushings wear down and you may be able to simply readjust the switch so its touching again.
beckya99
July 12th, 2011 12:29 PM
