88 chevy k1500 reverse problems
when i go thew the gears P R N D 123, my reverse light go on and than goes off,want i stop on reverse why? can someone help. all my lights work fine, back up, turns and brake, but not the reverse.::
Last edited by padilla; March 17th, 2014 at 2:59 PM. Reason: gera set up wrong, it sure be P R N D D 1 2
Sorry, the cluster thing im thinking of newer body style. If it flashes but does not stay on when shifted into reverse, it can be an issue the neutral safety switch on the side of the transmission. Might be something simple as and adjustment or may need to be replaced.
Park/Neutral Position and Backup Lamp Switch Adjustment
- Check the switch for proper operation.
- The engine must be in the P (Park) or N (Neutral) positions only. If adjustment is required, loosen the switch retaining bolts and rotate the switch slightly.
- Tighten the bolts and check the switch for proper operation.
- Repeat the switch adjustment procedure until the engine starts when the shift lever is positioned in park and neutral.
shaffer21
Silverado & Fullsize Pick-ups
February 19th, 2015 8:31 AM
Morphsuit
October 8th, 2013 6:06 AM
