97 Chevy Reverse Light Problems
Old Mar 17, 2010 | 9:14 AM
bioDAWG's Avatar
Default 97 Chevy Reverse Light Problems
Ok so my reverse light are not working on my truck (97 Chevy K1500 Z-71) and have not worked for awhile. I have checked all the fuses and mad sure the taillight connection was good but I can not for the life of me get the reverse lights to work. Is there a reverse sensor some where on the truck that could have possibly failed? If so where is it and what is the part called cause I have tried doing a parts search and can't find anything. I have also tried finding a reverse relay but have not be able to do so!
Thanks
Old Mar 17, 2010 | 9:33 AM
eisenhauer01's Avatar
does it keep blowing a fuse? or do they just not work? the backup lamps are constantly grounded.. just waiting for power to be applied to them via the light green wire (ckt 24).
here is a wiring diagram. if you have checked the fuse and ground for the bulbs.. then the problem might be the park/neutral position switch. I am assuming your truck is an automatic.
hope this helps.
Old Mar 17, 2010 | 9:39 AM
bioDAWG's Avatar
It is not blowing an fuses. The only lights that do not work are the reverse lights and I have checked the bulbs and the filaments are still good. I will have to prob the GRN reverse power line and see if it is getting any voltage in reverse. If not I am assuming it is the park/neutral position switch, correct?
Old Mar 17, 2010 | 9:44 AM
that is what i would start with.
Old Mar 17, 2010 | 9:48 AM
bioDAWG's Avatar
Ok, Thanks for the info. I will check the voltage of the reverse light connector. I am assuming the park/neutral position switch in located around the steering column.
Nevermind...I found it and the location. All the parts places refer to it as the Neutral safety switch.
Old Mar 17, 2010 | 10:38 AM
correct, hope you figure it out
Old Mar 17, 2010 | 11:40 AM
maxxman04's Avatar
auto or stick?
Old Mar 17, 2010 | 1:17 PM
i believe he has an auto.
Old Mar 17, 2010 | 1:28 PM
maxxman04's Avatar
park/neutral safety/backup switch is down towards base of steering column. kind of a plate looking deal with one or two connectors coming out of it.
Old Jan 18, 2019 | 7:09 PM
Camp80's Avatar
Default 97 GMC K1500 5 speed manual transmission
Originally Posted by maxxman04
auto or stick?
my reverse lights won’t come on. I’ve checked fuses changed the back up switch and everything thing else. All of my other lights work perfectly. Does anybody know what it could be. Thanks
padilla
Mar 26, 2014 2:15 PM
slihp
11
Aug 16, 2012 2:56 AM
d1nonly34
May 9, 2009 10:21 AM
d1nonly34
Apr 2, 2009 11:14 AM
cavyone
Nov 28, 2007 2:41 PM
