93 1500 305 help
93 1500 305 help
Alright guys i have a 1993 1500 with a 305 and it has a mis and an intermittent long crank. Cap, Rotor, plugs, wires have all been replaced. As has the ignition module. I also just did the fuel pump. The mis was there before all of those repairs. What do you guys think it is or suggest to fix/check? The mis is most apparent when cold at idle in gear, through 2000-2500rpm Also, when i drive it on the highway for a while (20 mins) it pretty much completley goes away runs smooth with a slight mis at idle.
another thought would be to isolate it, run it for a few seconds and see if you can find a cold runner on the exhaust manifold, this is easier with headers
natemclain
Silverado & Fullsize Pick-ups
August 4th, 2009 10:46 PM
Capitanbadass
February 27th, 2008 7:26 PM
