Notices
Sponsored by: DashLynx
93 C1500 Funky A/C Issue. Need Advice
Old August 2nd, 2012, 12:07 PM
rald277's Avatar
Default 93 C1500 Funky A/C Issue. Need Advice
First time poster here. I have a 93 Silverado with a 5.7L. It was converted to 134a about a year ago. The A/c has been working great until today. I was driving with cold air when all of a sudden it started warming up in the cab. Checked under the hood and the clutch on the a/c was not engaged. I tried to bypass it to check the freon but it would not bypass. I put a meter on the bypass (pressure switch) wires and had no voltage to ground. Did a little hunting on the web and found the location of the clutch relay behind the glove box. There were four of them. They are all the same and not knowing which of the four operated the A/C clutch I mixed them around to see if that would get the clutch to engage. It did not and I still had no voltage at the pressure switch. All fuses in the panel were good as well. Can anybody tell me what I'm missing?
Thanks in advance.
Old August 2nd, 2012, 2:51 PM
kevinkpk's Avatar
Did you check the fuse?
Old August 3rd, 2012, 10:04 AM
rald277's Avatar
"All fuses in the panel were good as well"
Old August 3rd, 2012, 11:44 AM
Check the wiring to the clutch for any breaks or frayed insulation. Try and trace it back to the relays. You can also remove the relay and check the contacts in the fuse box for 12 volts.
dannyboyindc
Express & G-Series Vans
February 17th, 2014 12:15 AM
sdavis_0204
October 6th, 2012 12:50 PM
thomastedder
May 18th, 2012 3:28 PM
Duke72
November 28th, 2010 10:25 AM
doo600
November 26th, 2007 11:07 AM
Quick Reply: 93 C1500 Funky A/C Issue. Need Advice
