97 Silverado Problems
Old Aug 14, 2010 | 8:46 AM
djm1951's Avatar
Question 97 Silverado Problems
Hi all. My truck has an issue with either a miss or a kick. You can be accelerating or just cruising along at any speed and without warning it will either miss or kick. The harder you are stepping on the gas the harder the kick. It doesn't do it all the time. Any ideas?
The steering is pretty loose also. What do I need to do to tighten it up?
The headlight are not very bright either. The plastic lens are really not that bad. What ya got for that?
Thanks all. Appreciate your knowledge.
Old Aug 14, 2010 | 9:06 AM
maxxman04's Avatar
miss/kick: when was last full tune-up?
headlights: all wiring ok? if so, use the Silverstar or Silverstar Ultra bulbs
steering: check tie rod ends, ball joints, control arm bushings, pitman arm, idler arm. basically all suspension and steering components and bushings. replace worn parts, have alignment checked/adjusted. still loose? probably worn steering gear box.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
wayne77&Trish
Sonic (Aveo)
Jun 9, 2016 12:54 AM
mwehrste
Dec 29, 2014 11:19 AM
GrayHeadedMule
Jul 9, 2013 10:16 PM
Big C
Sep 2, 2011 4:39 PM
