Adding lift blocks
Adding lift blocks
Hello,
I am adding lift blocks onder my C1500 '94.
I've undone on 1 side the U bolts. Some one told me I must work
one side at a time. Then I had to raise the chassis, but the leafs
stick on the axle. What should I do ?
thx
thx
the head's of the leaf spring center bolts are stuck to the top of the axle spring mounting pad . they hold the spring centered and in place till the u-bolt's are tightened .squirt a little penetrating oil around the base of the spring let it set and work awile with a little pressure lifting up on the back of the truck leaving the axle suspended ,with a jack under it .
latropa
April 17th, 2014 9:27 PM
GMJack38
Silverado & Fullsize Pick-ups
January 1st, 2011 12:28 PM
tmcelveen1985
August 28th, 2009 11:33 AM
