Notices
Axle removal
Old December 9th, 2009, 10:18 AM
bigben's Avatar
Default Axle removal
Hi I have a 2000 Silverado 4WD I am replacing all the brake lines Pads etc.
Found out that passenger side rear axle seal was leaking so bought new ones and want to replace those.
From what I found on the web is that there should be an 8 mm bolt in the differential that has to come out.
I have the cover off and rotated the axel a 100 times but I don't see that bolt. Is my rear end different or am I blind?
Is there anybody with a drawing or picture of this?
Any help appreciated.
Ben
Old December 9th, 2009, 10:48 AM
myotherchevyisablazer's Avatar
hey ben,here is a ok video of the inside of your 10 bolt axle with c-clips
doesn't show everything but i think it will get you headed in the right direction....if i were closer i would help ya with george and his shop....it doesnt matter if it's a video from a car all the same in the rear except for axle lug counts
http://www.youtube.com/watch?v=WqdmUPWpI9c
where is george when you need him......GEORGE
Old December 10th, 2009, 8:23 AM
bigben's Avatar
Thanks
I have the axell out.
I was spinning the wheel side not the drive shaft.
After seeing the youtube clip I took the drive shaft off and it was a piece of cake after that.
Again thanks for the tip.
Ben
Old December 10th, 2009, 10:27 AM
no problem ben...let me know how it turns out for you!
red
Old December 10th, 2009, 8:06 PM
Ride of the Month
May 2009
mudmaniac's Avatar
I knew you could handle it Red.
Russ300
September 9th, 2014 2:10 AM
kickstartjoe
September 15th, 2008 9:02 PM
dcathey
September 3rd, 2007 7:21 AM
flstfse
September 30th, 2006 7:28 PM
BCKNBLK
June 26th, 2006 11:41 AM
Quick Reply: Axle removal
