Old Jul 27, 2015, 3:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
belt squeak, but not the belt? help please
Old Apr 27, 2012 | 10:33 PM
landon101's Avatar
Default belt squeak, but not the belt? help please
hey all i have a 1997 chevy 1500 4x4 5.7 and ive been hearing a loud squeel while idling and driving so i changed the serpentine belt and also the auto adjustment.."pulley"?( not sure exactly what its called) but the one you can leverage down to take off the belt. Is there something im missing what else could the noise still be coming from?
Old Apr 27, 2012 | 10:51 PM
MDTAHOE's Avatar
Professional Mechanic
Take the belt back off and start the truck, is the noise still there?
Old Apr 27, 2012 | 11:19 PM
landon101's Avatar
i will try that in the morning, what would be possible issues if it does or doesn't?
Old Apr 28, 2012 | 6:48 AM
Try the idler pulley, the bearing may be going bad. Where did you buy the serpentine belt? I changed mine a while back and the noise got worse. After trying everything I could think of, it turned out that Autozone sold me the wrong belt. A little too long.
Old Apr 28, 2012 | 8:46 AM
grumpychevy's Avatar
WD40 the front of the alternator and pulley and see if the noise stops. I had this problem and it turne out that a bearing inside the alt was squealing. Had to change the alternator.
Old Apr 28, 2012 | 10:11 AM
landon101's Avatar
i got mine from orielys, though im pretty sure there the same length i compared the old one and the new one
Old Apr 28, 2012 | 10:12 AM
landon101's Avatar
one thing i forgot to ad..after i changed the auto adjustment pulley the noise was more consistent, any thoughts?
Old Apr 28, 2012 | 10:51 AM
The auto adjustment pulley is called the tensioner. This means that the problem is more likely in the idler bearing or possibly in the alternator bearing.
Old Apr 28, 2012 | 5:48 PM
RacerX's Avatar
...even possible, water pump pulley bearing also. Since we arent there we dont know if what you meant is a "squeal" a "squeak" or a "chirp". But all of that could also be a bad water pump bearing too.
Old Apr 28, 2012 | 9:54 PM
cleveland63b's Avatar
take the belt off and start it like mdtahoe suggested, if its gone spin every pulley by hand. If anything squeaks or growls replace it, try spinning the alternator by hand both directions or sometimes you won't spin it fast enough to hear
