Old Jul 24, 2015, 5:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
Change Oil LIght comes ON
Old May 18, 2007 | 8:29 PM
Toby T's Avatar
Default Change Oil LIght comes ON
I bought this 2000 Z71 a few mos ago.. Runs great no problems.
I was due for a oil change. The check oil light came on... I checked it. The oil was about a quart low.. I added a quart the light went off..I got the oil changed the next day..
After having the Oil changed.. The Change Oil Light came on.. It comes on when I start the truck.. It goes off and does not come back on... Unless you restart..
Ok guys were do I start.. 2,000 with 113,000 miles on it
Old May 19, 2007 | 11:08 AM
MalibuMaxxSS's Avatar
Default RE: Change Oil LIght comes ON
confused here....ALL dash lights will cycle when you start the truck....if it does not stay on then you are ok, just check it see if its low again maybe you have a leak.
Old May 19, 2007 | 3:46 PM
Intruder's Avatar
There is a little process to go thru to get it to reset, but I don't recall what it is - click your heels together 3 times and say "There's no place like home." "There's no place like home."
Has to do with turning on the key without starting and stepping on the brake pedal 3 times - or something like that.
"Luke - read your Owner's Manual."
Old May 19, 2007 | 4:40 PM
hunt4game29's Avatar
Turn your key on and press the gas pedel three times and then the oil light resets it self.
Old May 20, 2007 | 8:47 PM
Toby T's Avatar
Thank you Hunter.. I should have know there were some dip sticks out there who don't even know jack sheet. Some one did email me with the right information..
As you said depress the gas pedal 3 times in 5 seconds.. That took care of my problem.
Thank all you guys..
Old May 20, 2007 | 11:07 PM
Intruder's Avatar
Ah - You're welcome! And who doesn't know jack?????
Old May 21, 2007 | 10:00 AM
lost_in_alabama's Avatar
The oil change indicator is telling you that the oil needs changing. Nothing to do with oil level or oil pressure. The computer has a algorithim that tracks engine running time and the speed that the engine is running at.
Old Jan 25, 2008 | 1:26 AM
RickCoMatic's Avatar
Alabama hit it on the head. The Oil Life Monitor was monitoring how you drive and telling you that the oil's lubricating qualities for the conditions you place upon your vehicle indicate that it's time for Oil and Filter.
Old Jan 25, 2008 | 3:47 PM
Kev250R's Avatar
So is it best to wait to do an oil change until this message comes on or is it still best to stick with a standard 5,000 mile schedule?
Also does anyone do oil changes based on hours of run time? If so how many hours between oil changes do you go?
--Kevin
bobbygrady
Feb 18, 2014 10:12 PM
Toby T
Mar 14, 2008 5:16 PM
Toby T
Feb 21, 2007 1:59 PM
digdug
Feb 4, 2007 3:08 PM
canadiangurl
Aug 20, 2006 2:35 AM
