Changing setting on backup camera
Old Aug 25, 2012 | 12:03 PM
Bap's Avatar
Bap
Unhappy Changing setting on backup camera
I have a '12 Chevy Silverado LTZ. I do not have the in dash navigation system. I am trying to get my backup camera to show the navigation lines. Manual says to push menu button and turn multifuntion ****...I am unable to figure this out............can anyone help
Old Aug 30, 2012 | 11:09 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Are you referring to the guideline overlay to help the driver align the vehicle when backing into a parking spot?
Louis
GM Customer Service
Old Sep 3, 2012 | 7:42 AM
Bap's Avatar
Bap
yes Louis I am. I have seen the instructions in the manual but it says to hit menu button then turn the multifunction ****............I can't figure out what/where is the multifunction **** I have turned everything in there! The only menue button I have is on the radio.........is that the one.....jeez I know it must be something simple.
Old Sep 3, 2012 | 5:20 PM
staggerlee's Avatar
If you don't have the NAV system, why would you look for NAV lines?
Your backup camera will only come on in reverse and blind you.
Seems it picks up the backup lights and they blind you if you try to use it.
I'm going to experiment with some masking tape on each side.
Actually I don't need the camera, and wife can't backup.
So maybe just tape over it.
Lee
Old Sep 9, 2012 | 5:14 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I sent you an email regarding this issue, however, thought I would post in the forum as well, in hopes that it may help someone else in the future.
After additional research, I have found that the guideline feature is only available via the navigation unit. I'm sorry, but this feature is not available via the rearview mirror display.
I hope this information is helpful. If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Oct 13, 2012 | 2:36 PM
staggerlee's Avatar
Default Garmin
If you have a Garmin like mine.
It don't have to be as large as mine ( 7" screen).
It can be attached to the Garmin showing whats behind you.
The view can also be reversed.
Have heard the higher its mounted the better.
I don't have one yet, but will try mounting on rear of cab to stay away from the backup lights.
Lee
nilsm
Aug 26, 2023 9:29 AM
oresell
12
Apr 13, 2016 7:07 PM
gambianoca
Feb 24, 2007 3:13 AM
tomd
Jan 17, 2007 1:03 AM
hawaiifiveO
Oct 23, 2006 2:54 AM
