Chevy Transmission?
Chevy Transmission?
I have a 1995 chevy K1500 four wheel drive, automatic, that when I shift it from park to Reverse or drive it doesnt engage, unless I shut it offlet it set for a minute then it will engauge and go only a few hundred yards. There is some chattering noise underneath where the linkage goes into the transmission. What should I do and how can fix it myself?
RE: Chevy Transmission?
First of all, hows the fluid look and how much is in the tranny? Gotta ask the obvious first.
Sounds like it could maybe.. sorta... ( this is a long shot) be the pump in the tranny going bad. That can cause a huge delay in shifting into drive, if-not, a complete failure to **** into drive. Pretty sure..
Does it only do it when the motor is cold? Or does it do that regardless of temp.?
I'm wondering what the rattling is. Maybe the 2-4 band not engaging the drum because of not enough pressure? That would sure be in line with the low fluid or bad pump theory.
Coravir
Silverado & Fullsize Pick-ups
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
fixen
October 20th, 2006 8:10 PM
