Cold air from Heater
I have a 2007 1500 work truck and now that its turning cold, I discover my heater is pumping cold air. Seems too soon to be a failed heater core. Has any one seen (and cured ) this problem? Any help is appreciated.
Thanks
Thanks
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Sorry to hear about your heater problems. Could you please provide a little more information so I can look into this further? You stated your truck was a 1500, is that a GMC Sierra 1500, 1500 Denali, 1500 Hybrid or Chevrolet Silverado 1500?
Louis
GM Customer Service
Louis
GM Customer Service
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> AXP,
Does the truck have a manual heating, ventilation and air conditioning system? Could you please pm me with your name and VIN number so I could look into this further? I look forward to hearing from you.
Louis
GM Customer Service
Louis
GM Customer Service
i've had this problem and it was simple and easy fix. The two hoses that run off the water pump into the firewall, these are hoses that give you warm air when the coolant runs over the heater core. Obviously one goes in and the other returns. Remove both hoses from water pump or firewall, but be careful you don't break the connections on the firewall because they're just plastic if you remove the hoses from there. The heater core is just vents that get garbage on them like rust chips and stuff, if you take a water hose and shoot water into the return line it will push all the garbage off those vents to give you warm air. Hope this was helpful
2cool4air
November 17th, 2012 3:52 AM
Supertwins
July 4th, 2011 11:39 AM
Mille Racer 69
Silverado & Fullsize Pick-ups
17
November 7th, 2010 4:19 PM
chadfanman
December 12th, 2009 12:31 AM
