Notices
cold starting problem
Old February 25th, 2008, 11:47 AM
lw62's Avatar
Default cold starting problem
I have a 2000 gmc jimmy with a 4.3 v6 and sequential fuel injection.The problemwith it is cold starts.It won't start without a shot of ether.After it starts and warms up it will fire right up until allowed to cool off overnight.Any ideas? Thanks
Old February 25th, 2008, 1:14 PM
dewey's Avatar
Default RE: cold starting problem
After the vehicle sits overnight, I'd check fuel pressure, key on engine off. If you have the central sequential fuel injection, that system isnoted for problems. Fuel pressure is critical.You might try running some injector cleaner through the system, see if it helps.
Are there any trouble-codes?
Old February 25th, 2008, 1:41 PM
ehhget's Avatar
The system may not be priming. Look in your fuse panel for an opening (it is not a fuse but rather an opening) that you can stick your test light in. If it lights up when you turn the key it is priming, if it does not it isnt thus youmay be starving for fuel at startup.
Old February 25th, 2008, 3:11 PM
06chevy5.3's Avatar
i would dump a can of fuel injector cleaner in the tank just so it can clean out all the fuel lines and injectors, thing always seem to mess up and work slower when its cold.
jason33
November 14th, 2012 12:42 PM
Supertwins
July 4th, 2011 11:39 AM
jeff_cofer
February 3rd, 2011 3:19 AM
Mille Racer 69
17
November 7th, 2010 4:19 PM
Quick Reply: cold starting problem
