Notices
Sponsored by: DashLynx
converting rearend
Old December 27th, 2009, 11:40 AM
davbell22602's Avatar
Default converting rearend
90 2500hd 8 lug wheels. I want to know where to buy the kit(s) to convert my rearend to posi track/limted slip rearend?
Old December 27th, 2009, 5:56 PM
nauticstar87's Avatar
You prolly have a 14 bolt rearend. You can google 14 bolt posi and find what your looking for. Eaton is a great brand. I had a detroit locked dana 80 in a 81 f-250. That was the best rear axle set-up I've ever had.
Old December 27th, 2009, 6:43 PM
I have 3.73 ratio. I dont know if you guys know what brand of rear that is though.
Old December 27th, 2009, 6:55 PM
The easiest way to tell, count how many bolts hold the diff cover on, I'm pretty sure its a GM 14bolt. A 77 chevy 3/4 ton has basically the same 14bolt my 2007 3/4ton has, Except I have disc brakes, thats the biggest difference. I doubt you have a GM 10bolt, thats a half ton axle, the light duty 3/4 tons had a 10 bolt 6 lug i beleive.
my 07 has 4.10s But it's still a GM 14-bolt. If it had 3.73s it would still be a GM 14-bolt. Some are known as a Corporate 14-bolt.
Old December 27th, 2009, 7:04 PM
ok but I have drum brakes on my rearend though. 16in wheels too.
Old December 27th, 2009, 7:12 PM
http://www.rearendparts.com/product.php?productid=645
Theres you a link. You can call them and find what you want for your application, You should have a full floating 14-bolt rearend. Full floating means, at least to my knowledge, you can pull the axle shafts out with out opening the diff cover, theres no c-clips holding the axles into the diff.
Old December 27th, 2009, 7:54 PM
thanks for the info.
Old December 28th, 2009, 5:40 PM
I decided to do a complete axle swap. I 'll be swapping my 3.73 ratio for a 4.10.1 limited slip axle.
Old December 28th, 2009, 6:34 PM
myotherchevyisablazer's Avatar
is this going into a 2wd?
Old December 28th, 2009, 6:57 PM
yes, going into a 2wd.
TD83
11
December 18th, 2019 2:30 PM
cannon44
Cobalt
February 15th, 2010 11:38 PM
65cammy
July 22nd, 2009 12:22 AM
KER0143
September 29th, 2008 7:11 PM
bob101290
September 1st, 2008 12:02 PM
Quick Reply: converting rearend
