Crackling radio
Crackling radio
Just bought a new 2022 Silverado RST and the radio started crackling 3 weeks in when the volume went over 50%. My neighbor said to check the AMP fuse and while I was looking around in the fuse box, I noticed that almost every fuse and relay was loose or not seated properly. I pushed every fuse down to check that it was seated correctly. The radio issue is now gone. Do you think this is a fluke or a bigger issue with the fuse block? I saw that there was a GM issue a few years ago, not sure if it is still an issue? Never found a fuse associated with an amplifier. Seems that the interior electronics are in the cabin fuse boxes. Will check those as well.
FXchopper
May 12th, 2020 3:53 PM
