Notices
Sponsored by: DashLynx
Crew Cab Back Seat Rattle
Old November 2nd, 2010, 3:18 PM
wellingtontx's Avatar
Default Crew Cab Back Seat Rattle
I just picked up a 2009 Chev Crew Cab. When driving over a bump, it sounds like either the passenger side back door rattles or more likely the rear back seat on the passenger side is rattling. Anyoone else have this problem or know of a solution ?
Old November 2nd, 2010, 11:02 PM
wjbyrd36567's Avatar
Mine was doing the same thing, ended up being the rear seatbelts banging against the plastic by the door. I just buckled them up and it stopped my rattle.
Old November 3rd, 2010, 8:50 AM
It sounds like a heavier banging/rattle. I thought it might be the seat belt as well and tried the buckle idea - no luck, but thanks for the suggestion.
Old November 3rd, 2010, 10:35 PM
may try having a buddy ride in the back and help locate the culprit.....
Old November 3rd, 2010, 10:39 PM
chase050505's Avatar
check to see it the back of the seat will move up and down a little with out using the lever if so it may be the recliner or whatever its called
Old June 18th, 2014, 12:49 PM
Brolow7's Avatar
Its none of the above. Mine is doing the same thing. Its some little d shaped anchors behind your seat. to really fix the issue you need to insulate them so your back seat isnt rattling on the clips. duct tape or sliced rubber tube will do the trick. it does involve taking your seats out though.
Old May 31st, 2015, 5:53 PM
ksbikr's Avatar
Unhappy Rattle around center post on crew cab 2008 Silverado (45,000 miles)
I have tried everything mentioned and still have the rattle. Sounds like it is coming from lower part of center post area. Changed the rear seat clips as one was broken (was sure that would cure it -(NOT). BTW I glued them in place in case they break again they won't fall out of the bracket. I loosened the step rail, remover everything from under rear seat area. There is no movement on the rails of front passenger seat. Removed center post plastic cover and shimmed front and rear seat belt swivel brackets. Nothing loose under the truck. If anyone has solved the problem by some other method please let me know or I'm going to switch brands next purchase as rattles drive me crazy.
Thanks
Old June 1st, 2015, 8:10 AM
The only way I have solved is by wrapping the little brackets with duct tape. The insulation provides just enough padding to stop the rattle. I think they have solved on 2015s
Old June 1st, 2015, 8:21 AM
ksbikr's Avatar
Are you referring to the brackets behind the rear seat toward the top of the seat? I pushed and pulled and tried to see if there was any movement on the back seat after replacing the plastic clips and could not get any movement but I will remove the seat and wrap the u shaped bracket if this is what worked for you.
Thanks so much for your help.
Old June 16th, 2015, 8:18 AM
mikebar4's Avatar
mine was doingthe same thing.. Drove me crazy!!!
I removed seats and wrapped the brackets in tape..... Problem solved!!!!
JustinL
August 23rd, 2014 12:54 PM
Tavo Govea
February 7th, 2012 12:12 AM
lj444
January 9th, 2008 9:23 PM
mikewaterskis
22
October 10th, 2007 8:47 PM
kc01976
May 17th, 2007 5:53 PM
Quick Reply: Crew Cab Back Seat Rattle
