THIS FORUMN IS LAME NO REPLYS
THIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYSTHIS FORUMN IS LAME NO REPLYS
RE: THIS FORUMN IS LAME NO REPLYS
Final Solution: It was the Fuel Pressure Regulator. $50.00 at Kragen Auto Parts. One thing I found is that when you pull the old FPR out make sure you get all the old parts out of the hole. There will be the little round washer/screen/and a bigger round washer.
VERY IMPORTANT: I layed a water soaked towel under the FPR as the engine was a little warm yet. (GAS/HEAT) you know the drill...You get quite a bit of gas that is under pressure that will come out. Use caution....
Starts like a chevy shouldnow......within 1-2 seconds every time.....
tony72
November 18th, 2014 1:57 PM
