Notices
fuel pump, 93 C1500
Old July 8th, 2010, 3:24 PM
sawblade's Avatar
Default fuel pump, 93 C1500
I have a 93 C1500 that I’m pretty sure needs a new fuel pump. I pour a little gas in the carb and she starts right up. I had a buddy under the truck and while trying to start it, he hit the tank and she started right up.. Did this Twice.
My questions the local parts stores have a complete fuel pump assembly for around $200 and also just the pump for around $60.
Does anyone have experience to tell me which way I may want to go.. or avoid?
I also found a cheap complete unit on the net for $110.. Not sure about that one..
Is it easier to remove the truck bed to replace this thing?
Old July 8th, 2010, 3:37 PM
maxxman04's Avatar
you can replace just the pump easy enough. drop the tank, or remove the bed, really up to you. invest in a GOOD pump tho. some of the cheaper ones, and internet specials, ain't very good. this from personal experience. also, attached to the end of the pump is a strainer/filter. replace this as well. and replace the wire harnes too. you'll see why when you pull old pump. over time, the stock wires tend to melt a bit, creating a fire hazard. a new harness is cheap and available at most parts stores. buy it, use it.
Old July 25th, 2010, 9:31 PM
91chevyk1500's Avatar
i would suggest taking the bed off but like he said its up to you i usually take the bed off then drop the tank
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
cptnamr7
June 9th, 2014 7:23 AM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
Quick Reply: fuel pump, 93 C1500
