fuel pump aint working
ok i just got everything done on my intake manifold switch "carb to TBI" when i had my carb on the engine i just unpluged the fuel pump right next to the gas tank... i have checked the following: fuel pump fuse, good/ fuel pump relay, "i dont know how to check it"/ and i have a decent amount of power going to the pump... i un-hooked my batt. for the night and when i got done putting it together i pluged it in so it should have reset the comp... im at a lose.. how do i check the fuel pump relay?? and is it possible for a pump to burn out if it aint being used?? it still was wet with gas i never took it out of the tank the manuel fuel pump was sucking the gas through the pump could that be what burned it out??
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
BRB
Silverado & Fullsize Pick-ups
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
78monteripper
November 10th, 2009 1:24 PM
