Notices
Sponsored by: DashLynx
Grinding and rubbing while turning to decline or slanted surface
Old February 5th, 2014, 1:37 AM
jglm77's Avatar
Default Grinding and rubbing while turning to decline or slanted surface
This is driving me crazy because I've spent thousands on trying to find a solution. I've replaced my ball joints, hub bearings, driver side cv axle, and other things that I don't think are related to the problem. But I still have this grinding noise as I turn on to a declined surface and I can actually feel my truck slowing down. I don't think it happens on an incline. I've googled a solution forever but nobody seems to have the same problem. So I just joined this forum in hope that someone can help me find an answer before I spend any more money.
Old February 5th, 2014, 4:15 AM
Allan In NE's Avatar
Kinda need to know what you're working on......
Allan
Old February 5th, 2014, 4:34 PM
jglm77's Avatar
Allan
Hey Allan I'm just trying to find out what the noise is. I guess I don't really understand your question.
Old February 5th, 2014, 9:23 PM
Welcome to the forum...
What year and model... does it do it all the time or just doing when its cold out... at 40F and lower my front sway bar bushings make a lot of scrunching noise....
Old February 5th, 2014, 10:44 PM
jglm77's Avatar
in2pro. It's an 08 silverado 1500. And I live in Hawaii so it doesn't get very cold, even in the winter the lowest temp is 60.
Old February 6th, 2014, 11:40 AM
Wow that must be nice... 60 degree evenings...its 25 degrees this morning here in central Texas...
Might want to check the brake calipers and bolts, the calipers need to slide some what easily on the pins...
Old February 6th, 2014, 4:04 PM
jglm77's Avatar
in2pro, thanks I'll check out my calipers
Old February 16th, 2014, 3:43 AM
jglm77's Avatar
Just got my cv axles re-replaced and that fixed it.
Old February 16th, 2014, 11:36 AM
re-replaced ....thanks for the follow up...
Old February 16th, 2014, 6:49 PM
jglm77's Avatar
Yes I had one replaced a few months back so I assumed that couldn't be it but recently I saw grease splattered all over my wheel well. Got them both replaced and that seemed to fix it
Quick Reply: Grinding and rubbing while turning to decline or slanted surface
