Help tuning a big block 350 w/ edelbrock carb
#12
When we check vacum lines we start checking them where the hose clamps are or the spot with the most bend. If it is the vacum lines its an easy fix easy to check them to we just buy a can or two of starter fluid and spray a litlle as you work your way around if it revs up you found your leak. i hope it is the vacum lines i wanna see some videos of that thing in action. 02dirtyd that is an awsome rig and the old international cab probably is stronger then most newer trucks with the roll bars i should go pull one of the cabs outta one of the old ghost mines and build on up like that. 52'' tires forget a boat id drive that up the river duck huntin
Onyxia
Silverado & Fullsize Pick-ups
September 2nd, 2013 6:17 PM
Dwainoo
December 7th, 2010 2:53 AM
viborero23
December 5th, 2009 8:03 PM
