Need tire suggestions
Hi, I bought a used 1991 Silverado k1500 4x4. The tires are worn P265/75 R16 114S. I'd like to replace them with a set of LT tires. Which LT tire sizes can I use without changing rims?
Thanks
80skeys
Thanks
80skeys
I think you need to worry more about the clearance of the fender wells if you go any bigger than the 265/75 and not the size of the rim on that year of truck, you may be able to squeeze a 285/75 in there but the tread can't be real deep. On a 97 I had I put 265 /75/16 Buckshot Maxxis Mudders on them and only had about an inch to two inches of clearance when the wheels were fully turned in the stock fender wells.
jrmoeller23
Silverado & Fullsize Pick-ups
August 11th, 2010 4:32 PM
