Notices
Sponsored by: DashLynx
New Fuel pump turns on, but wont pump fuel
Old October 27th, 2021, 6:40 PM
Joe_The_Guy's Avatar
Default New Fuel pump turns on, but wont pump fuel
I have an automatic 2003 silverado 5.3 that stopped running. It had air and spark, but no fuel pressure so i decided to replace the fuel pump. Installed the new pump, but there's still no pressure. The new pump required me to re-wire on a new electrical connector. I believe i did that correctly since the gas gauge works and when i turn the key on, the pump hums. When I have the fuel lines disconnected from the pump and turn the key, the pump hums but nothing comes out at all. The tank is half full.
Old October 27th, 2021, 9:42 PM
pump may be wired backwards. the big wires to the pump and smaller to the sender... but maybe the pump is spinning backwards?/?
returnless fuel system or does it have a return line to the tank? if it has a return line it will have an external fuel filter. it should be changed when a new pump is installed.
hard to recommend anything on the wiring without knowing the pump you have....any wiring diagrams for the new pump?
Old October 29th, 2021, 2:26 PM
yeah the pump was wired wrong. The wiring instructions weren't clear about specific year models and there were about 4 possible combinations. I was just confused as to why the pump was turning on and not pumping anything. I think you were right about it spinning backwards. Appreciate it.
Old October 29th, 2021, 9:50 PM
carter pump? they are confusing....they should provide the diagram for the pump they sell you....instead they list options for a pump from another kit.
Joe_The_Guy
October 27th, 2021 6:28 PM
XAQSHNR
K5 Blazer
March 29th, 2020 5:16 PM
gumby197
November 6th, 2010 12:55 PM
Matt Luke
August 24th, 2007 5:26 PM
Enstar
13
June 22nd, 2007 10:36 PM
Quick Reply: New Fuel pump turns on, but wont pump fuel
