No Interior lights with good fuses
Morning,
My 2002 Chevy 2500 HD 6.6L has 345,000 miles and will still light um up but my interior lights don't. Got it used 5 yrs ago and the dome light, door lights and under the dash lights don't come on when you open the door. When you open the door there's no light on the dash indicating a door open. The radio turn's off after you open the doors. The navigation lights work when you push the buttons.
I've replaced the (BCM) Body Control Module and had a shop program it. I get 12v on all the orange wires to the sockets. There's no continuity on the white wire. When you but a bulb in the dome and doors, I have 12v on the white wire. Which makes since completing the circuit. So I grounded the white wire and the lights work. But guess what, they don't shut off now.(of course I took my wire off so i don't drain the battery). When I push the unlock button the door light, lights up very dim.
I tore the panels off and half of the damn dash apart trying to find a broken wire or short with a power probe wire tracer. The power probe says it's a open circuit. I checked all plugs at all for doors and unplugging them. One of the relays were missing by the brake pedal and I installed a new one. Sounds like a bad ground wire right, but where?
Please Help
Thanks
Please Help
Thanks
Morning,
Please Help
Thanks
Please Help
Thanks
You need to get an electrical schematic and component location diagram to find and inspect all your ground circuits.
After that you'll have to deal with the "always on" problem, but it'll be easier.
dadsmetal (March 24th, 2020)
rganner
Silverado & Fullsize Pick-ups
December 19th, 2013 1:07 PM
