Notices
Sponsored by: DashLynx
Sea Foam
Old August 9th, 2010, 2:06 PM
Capt Dave's Avatar
Default Sea Foam
I have heard of Sea Foam and want to know if it actually works before I go and buy some. Thanks!!
Old August 9th, 2010, 2:09 PM
maxxman04's Avatar
better than anything else!
Old August 9th, 2010, 2:19 PM
gotstylez's Avatar
worked for me.. i didnt put it in the oil..but everthign else i did do..
Old August 9th, 2010, 6:26 PM
s34n's Avatar
sea foam is awesome. and works great.
Old August 9th, 2010, 6:39 PM
julosibia's Avatar
excellent product.........also try marvel mystery oil.cant go wrong
Old August 9th, 2010, 8:23 PM
wellmax's Avatar
i use it in the fuel systems of all my vehicles
also use it in all my small engine fuel tanks.
Enothol fuel is rough on the small engines and a small amout of seafoam in the tank has kept them running strong.
Old August 11th, 2010, 8:50 AM
ffmed6134's Avatar
I have used Sea Foam for a long time and it is truly a great product, put some in the oil and just once in the tank, My dad uses it in his Diesel and he has never had his truck run any smoother.
Old August 25th, 2010, 8:00 AM
trojannnhorse's Avatar
Top of my list. Use it one a year in my oil,run it about 50 to 100 miles than change oil. What a diference it makes !! when i first used it i had a tapping in engine when I would first start it up for a couple minutes. After using Seafoam on oil change noise gone and has not came back since, also fell slight power increase!
Old August 25th, 2010, 6:39 PM
s34n's Avatar
trojan, you put the sea foam in the crankcase? i've never heard of that. so did you put it in your oil fill spot?
Old August 25th, 2010, 6:55 PM
jcgonzal's Avatar
Pretty sure on the bottle it has a suggestion of 1/3 in your tank, 1/3 in the crankcase, and 1/3 through the intake (brake booster vacuum hose). And yes, you just put it in the oil fill spot.
Quick Reply: Sea Foam
