Squeaking from front drivers side wheel
Old Oct 24, 2011 | 2:46 PM
saltylife1974's Avatar
Default Squeaking from front drivers side wheel
ok...I have a squeaking noise coming from the front drivers side wheel on my 2007 Z71 4x4 silverado...not really sure what it is or where to start since it randomly happens mostly if the truck hasn't been driven, once i warms up it goes away and seems to also only happen with I press on the gas, if i let off the pedal it stops.
The truck is lifted with a pro comp 6" lift and just hit 100k miles
really like to at least narrow it down so if its a job i cant do i can least call and tell the shop whats wrong to get better $ on this job
any help on suggests will be greatly appreciated
Old Oct 25, 2011 | 3:54 PM
No one on this? a friend mentioned something bout an axle joint...how can i troubleshoot this
Old Oct 25, 2011 | 6:26 PM
maxxman04's Avatar
things to check are brakes, bearing hub assembly, caliper bolts, ball joints. you can look at the tires, check for uneven wear, jack front end up, check for slop or play in bearing, spin tire while off ground, see if and where squeak is.
Old Oct 26, 2011 | 11:27 AM
ill try that...thank you
trackerdriver
Sep 20, 2015 10:53 AM
jlpolicky
Feb 17, 2015 2:04 AM
jmarkv
Jan 24, 2012 8:21 PM
cdeal
Aug 19, 2008 6:45 PM
