Old Jul 27, 2015, 3:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Starter sluggish when warm
Old Jun 25, 2011 | 3:46 PM
usmarine0905's Avatar
Default Starter sluggish when warm
98 silverado, 5.7, starter spins fine when cold or cool. but slow when warm, only when warm or hot. Battery is good, had it tested two different places, and batt is good.. So the starter, is my guess. So should I replace the starter assy or just the solinold assy? Yes there is a heat sheild on the starter....
Old Jun 25, 2011 | 8:31 PM
shamrock246's Avatar
i'm having the same problem with my 97 burb i'm going to check all the grounds first,my starter might be shot because of the crank postion sensor problems i had causing excessive ignition advance at start up it wrecked the ring gear on the flex plate
Sean
97 4x4 burb
Old Jun 25, 2011 | 8:46 PM
Given the age of the vehicle I would consider replacing the ground and the starter cable to the battery. They may look in good shape but can be corroded internally.
Old Jun 26, 2011 | 10:15 AM
OLD WRENCH's Avatar
All of the above can be the culprit,plus I have seen this happen when a batt was too small. (Not enough amperage)
Old Jun 26, 2011 | 12:21 PM
@ Old wrench..... understood.. last year I purchase a battery bigger that OEM.. the one I purchased is 950CCA
Old Jun 26, 2011 | 12:24 PM
@ in2pro..... ok understood... inaddition would that also be a cause of what I stated the problem was.... as i noticed that when warm, yes sluggish to spin.. but if i make one attempt, then stop, and turn key again, the spin start is almost normal again... she will spin the engine well....
Old Jun 26, 2011 | 11:01 PM
OLD WRENCH's Avatar
That should be plenty big on the batt. if it is good. The fact that it corrects itself points me to connections. A worn starter wouldnt get better. If you have a volt meter connect it paralell with the various circuits then operate the starter and see if you have a voltage reading this will be the voltage drop or loss in that circuit.Dont forget the ground side.
Old Jul 3, 2011 | 8:30 AM
whet thru all my connections found the positive starter connection a little loose and cleaned all the grounds not very dirty to begin with and my starter has no heat shield that is on order see if that helps, the starter looks new but it could have taken a hit when i had the crank sensor failing and it was giving way to much ignition advance at start up and ripped up my flex plate
Sean
97 4x4 burb
Old Jul 3, 2011 | 10:59 AM
Yup, when its cold the connection is poor but as it heats up the connections can temporarily get better due to the expansion due to heat, but it will break down the connection after a while as it can only expand so far.
Old Jul 3, 2011 | 6:03 PM
Thank to all that has provided input and advise...I checked all wiring,cables,grounds, etc's...and went out and purchased a NEW starter, direct drive, about half the size...drove it all over town as I do. stoping appx 8 times at different stores.. and letting her sit for 10 mins appx.. and no problem.. she spun and started rite up, no sluggish problem anymore... The starter was the issue.... thanks again......!!!!
Everyone
