Old Aug 10, 2015, 6:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
temperature in rear view mirror
Old Aug 24, 2007 | 10:43 PM
owens87's Avatar
Default temperature in rear view mirror
i just bout a 03 silvarado and in the rearview mirror it has a compass and temp the compass works but the temp keeps sayin "OC" on it and wont tell the temp outside ive took it to chevy dealers and they dont kno does anyone kno how i fix this?
Old Aug 25, 2007 | 9:48 AM
RonH's Avatar
Default RE: temperature in rear view mirror
There is a sensor in the grill area that measures the air temperature. The temp display in the mirror will read SC or OC if the sensor is bad, or if there is problem with the wiring, or if one of the connectors at the sensor or at the mirror does not have a good connection. Did any of the dealers do any testing of the sensor or wiring to try to find the problem?
Old Aug 25, 2007 | 12:26 PM
p.hinds's Avatar
you can pull the connector from the sensor and jump the 2 terminals with a paper clip.if the temp is still oc you likely have a wiring problem.rodents like to chew wires under the underhood fuse block.may want to look there.
dtme46
Aug 20, 2007 11:33 PM
cbr1r
Feb 16, 2007 8:06 PM
mic454
Jan 26, 2007 9:58 AM
jaymoore74
Colorado
Dec 22, 2006 7:50 PM
