Last edit by: IB Advertising
Browse all: Interior Guides
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Calibrate Rear View Mirror
temperature in rear view mirror
i just bout a 03 silvarado and in the rearview mirror it has a compass and temp the compass works but the temp keeps sayin "OC" on it and wont tell the temp outside ive took it to chevy dealers and they dont kno does anyone kno how i fix this?
There is a sensor in the grill area that measures the air temperature. The temp display in the mirror will read SC or OC if the sensor is bad, or if there is problem with the wiring, or if one of the connectors at the sensor or at the mirror does not have a good connection. Did any of the dealers do any testing of the sensor or wiring to try to find the problem?
you can pull the connector from the sensor and jump the 2 terminals with a paper clip.if the temp is still oc you likely have a wiring problem.rodents like to chew wires under the underhood fuse block.may want to look there.
