towing help!!
towing help!!
hi me an my father in law are buying a camper....my truck will pull it just find but im worried about his the trailer is 26ft weighs 4500 dry....he has a 2007 reg cab work truck with the 4.3 and a towing package will it pull it!!??
the 4.3 has the power to pull it. it depends on the gearing tho. if his truck has 3.73's or 4.10's, shouldn't have a problem. i wouldn't expect to maintain hiway speeds or pull hills at 60+mph, but it'll pull.
we have a 24ft trailer and I had a 93 gmc with v6 with the 3.42 differential,
it would pull the trailer but on long hills it would start to get hot, the truck was just overloaded.
currently I have a 2500 series with 350 engine and 3.73 differental even this truck has a bit of a problem with trailer on long steep hills. It only has 250 hp and 330 foot pounds of torque.
If you can get a 4.10 differential for the v-6 you should be able to pull the trailer, may want to also install a larger radiator.
If you have hills you still may not be satisfied with the trucks performance.
I do not like having to watch the temp gauge all the time.
Hi chadk8604,
Welcome to the Chevy Forums.
What it would help to know is:
Are you just towing it to a local campsite, within a couple hundred miles,
Or are you talking about long trips cross country on the interstate?
Because while I know there are things that suck worse than being broke down 5 states away from home on vacation, I can't bring any to mind right now.
I know somebody who used to tow a small trailer with a Lumina minivan without problems. But she limited it to very short trips. The Lumina-Trailer show wouldn't have lasted two days cross country, on the open road.
Nyron
Silverado & Fullsize Pick-ups
June 28th, 2010 10:55 AM
astrojon
May 26th, 2008 7:53 PM
