Notices
won't go into tow mode
Old April 28th, 2009, 10:53 AM
sammy's Avatar
Default won't go into tow mode
I have a 2000 silverado 4x4. The tow mode doesn't work most of the time. Anyone else have this problem?
Old April 28th, 2009, 6:20 PM
gpssurvey's Avatar
Hi Sammy,
There is sort of a known wear-point for the wiring for the tow mode button. This link does a pretty good job of summing up the issue.
http://www.justanswer.com/questions/...hased-used-tow
Hope this helps!
Old April 28th, 2009, 9:25 PM
jherkel's Avatar
did you check the fuse? there could be a blown fuse either under your hood in the electrical center or on the side of the dash behind the fuse cover on the driver side. if the fuse is good try looking for a loose wire or disconnected wire. thats all i can tell ya.
Old April 28th, 2009, 10:03 PM
suzuki-guy's Avatar
If the fuse was bad it wouldnt work at all not sometimes sounds like a short to me
Old April 29th, 2009, 12:53 PM
sammy's Avatar
The 4x4 switch on the dash took a dump on my way to work during a snow storm. It had been acting up I replaced it and founf 3 blown fuses. I thought maybe this was the problem it didn't fix it.
Old April 29th, 2009, 1:24 PM
sammy's Avatar
Thanks for info I will check this stuff this weekend. Suzuki guy what kind of suzuki do you have. I have a Samuria I built up for off roading.
Old April 29th, 2009, 5:12 PM
suzuki-guy's Avatar
i have a quad its a LT250r bored 60 over
Old April 30th, 2009, 9:04 AM
sammy's Avatar
I have an 88 Samuria with a 6" lift 31" tires locked front and rear with a gear reduction set in the tranfer case. I Also have Polaris and Honda 4x4 atvs my kids ride. I take my Samuria out with the local ATV club on rides, not a lot of places I can't follow.
georam1
October 17th, 2011 7:44 PM
mummp
October 13th, 2009 8:48 PM
steved
November 27th, 2007 1:27 AM
racerx55
May 17th, 2007 8:05 AM
Clay24
January 4th, 2007 1:37 AM
Quick Reply: won't go into tow mode
