01 Front Wheel Hub Assembly
Hi all, I have a 01 GMC Sierra 2WD with a bad front wheel hub/bearing assembly. My question is, do I need to use a threadlocker on the mounting bolts when replacing? Anything else I need to know before replacing?
Thanks,
James
Thanks,
James
well, the factory bolts do have compound on them. also, all nuts are pinch nuts. just be careful with the loktite choices - don't go red or lord save you, black. blue should be ok. 20 minutes to cure.
Read the post too late & used red. Think I'll ever get it back off if I need to replace again?
Have a new question; I need an upper balljoint. After removing the snap ring can the joint be knocked out or will it need to be pressed?
pdrayton
June 21st, 2018 6:55 AM
Stevoray81
October 30th, 2014 10:30 PM
