01 Front Wheel Hub Assembly
Old Dec 11, 2008 | 11:23 PM
jwko's Avatar
Default 01 Front Wheel Hub Assembly
Hi all, I have a 01 GMC Sierra 2WD with a bad front wheel hub/bearing assembly. My question is, do I need to use a threadlocker on the mounting bolts when replacing? Anything else I need to know before replacing?
Thanks,
James
Old Dec 12, 2008 | 12:39 PM
x1cn18's Avatar
Default RE: 01 Front Wheel Hub Assembly
i would suggest it cause my friends 04 backed cause they didnt
Old Dec 12, 2008 | 1:13 PM
jwko's Avatar
Thanks. Going to get started on it now.
Have a good weekend
Old Dec 12, 2008 | 9:25 PM
ukrkoz's Avatar
well, the factory bolts do have compound on them. also, all nuts are pinch nuts. just be careful with the loktite choices - don't go red or lord save you, black. blue should be ok. 20 minutes to cure.
Old Dec 12, 2008 | 9:33 PM
jwko's Avatar
Read the post too late & used red. Think I'll ever get it back off if I need to replace again?
Have a new question; I need an upper balljoint. After removing the snap ring can the joint be knocked out or will it need to be pressed?
pdrayton
Jun 21, 2018 6:55 AM
Stevoray81
Oct 30, 2014 10:30 PM
Tgunter5
Oct 17, 2014 10:23 AM
cyras21
Aug 1, 2011 1:37 PM
