Notices
02 2500hd randomly shutting off??
Old May 3rd, 2008, 7:10 PM
  #11
bubba_gump's Avatar
Default RE: 02 2500hd randomly shutting off??
ORIGINAL: stickershock
Check your battery connectivity at the posts. You may have corrosion which won't permit charging the battery effectively, so after running off the battery a while which then exhausts, poof... no engine.
Also, the Starter Crank Relay may be defective. It costs 9 dollars at most AutoZones.
Well, you wanted suggestions, right?
yeah but if that was the case then all the electrical systems and lightswill start dimming and you will feel a steady decline in the engines power. that problem would be obvious.
Old May 7th, 2008, 10:03 PM
  #12
bossman78's Avatar
also check the pos. wire to the starter i had one rubbing on the exhaust man. so it would short out periodically.
klwmat417
October 6th, 2013 12:18 PM
guariscoc
September 10th, 2011 3:36 PM
KG
March 2nd, 2007 10:48 AM
earm462
October 29th, 2006 1:42 PM
Coolguy0418
December 3rd, 2005 8:57 PM
Quick Reply: 02 2500hd randomly shutting off??
