02 Silverado 1500 4wd, Body lift questions
Old Apr 19, 2008 | 1:29 AM
02Silv's Avatar
Default 02 Silverado 1500 4wd, Body lift questions
Hi, I have a 2002 Silverado 1500 non-HD Z71 4wd w/ and automatic trans. I have a RCD 6in suspension lift on in already, I'm wanting to go higher. I was thinking of putting a 3in body lift on it. I'm not sure witch one to buy. I want to buy a kit w/everything I need. Any extension parts, clips, bumper brackets. Everything!! Also, I've never installed a lift before, will there be any welding or drilling. I'm only worried about welding because I do sheet metal for a living. Any advise would be Awesome!! Thanks
Old Apr 19, 2008 | 12:29 PM
northey87's Avatar
Default RE: 02 Silverado 1500 4wd, Body lift questions
Welcome to the forum!!! Someone here should be able to help, just hang in there.
Old Apr 19, 2008 | 9:34 PM
ehhget's Avatar
Save your cash until you can bump up your suspension lift more. Body lifts look tacky even with the skirts and your radiator goes up with your body away from your engine and stuff like that. If you have a nice suspension lift now you probably will not be happy. I almost made that mistake with my trcuk, glad I didnt.
Old Apr 19, 2008 | 9:59 PM
02Silv's Avatar
OK, thanks for the advice.. Dont I have to buy a whole new lift kit to do that or do I just have to buy new lifting blocks? Also I was thinking about getting a power programmer, I have been looking on the InnerAuto.com web site at the different kinds of chips and modules to get. I dont want anything to crazy but I definitly want to feel the difference. Any Info???
Old Apr 20, 2008 | 11:07 PM
ehhget's Avatar
On the rear you can step up the blocks, on the front probably have to change your spindels depending on how much more you want it depends on the type of lift you have check with a lift shop they will be able to help. I did a hypertech, noticed a little on low end but dont expect it to feel like you added a turbo its not a huge difference but it helps and it lets you adjust for larger tires which Im sure you have.
RUTRAKIN
Aug 7, 2015 11:05 PM
D Chevy
Sep 17, 2012 12:06 PM
motichka218
Mar 9, 2011 6:42 PM
bigohagen
May 31, 2008 6:17 PM
Joetheshow
Apr 15, 2008 11:21 AM
Top
Follow Us
