02 Silverado 1500 hd brake issue at low speeds
Old Jun 26, 2024 | 11:34 AM
Davidaguileran's Avatar
Default 02 Silverado 1500 hd brake issue at low speeds
Hi all, looking for some advice here.
My 02 Silverado 1500 HD has been having an issue with the brakes , I finally replaced all the brake pads all around even tho the ones I took out were almost in new condition,
The issue is , at low speeds mostly parking into parking spaces, the brakes will not fully engage, is like the abs kicking in and letting the truck roll, I can feel the brake pedal "kick back" and the brakes feel like are skipping if tyat makes any sense, a couple of times I have had to press the brake pedal very hard in order to stop the truck , at high speeds brakes work normal.
Changing the brake pads did not solve the issue, I am wondering if anyone else had this same issue and has found the problem and the solution.
Thanks in advance.
Old Jun 27, 2024 | 10:37 PM
you probably have malfunctioning wheel speed sensors.
Old Jul 9, 2024 | 10:23 AM
pyoung015.3's Avatar
My truck does the same thing, your wheel speed sensor is getting eaten up and tricking your abs system into thinking one wheel is spinning faster than the other.
Jiyu
Apr 29, 2024 5:36 PM
EaterOfAss
2007 - 2013 (GMT900)
Aug 8, 2021 8:00 AM
motc7777
Jul 22, 2021 4:29 PM
rgarcia410
Jun 19, 2014 2:43 PM
mrwalker534
Nov 13, 2011 8:57 PM
