03 4.8L wants to die-I need help!
my 03 4.8L 2wd silverado wants to die on me when at idle and when im decelarating from high speeds or going around turns. The battery/alternator are good and it starts up everytime just fine. I talked to some mechanics and no one seems to know the problem. Any help/suggestions is greatly appreciated. --Thanks
RE: 03 4.8L wants to die-I need help!
make sure you're getting fuel. check the fuel filter (is it dirty/clogged?) make sure you have no leaks in the lines, fuel injectors (everything in the first post) maybe your fuel/air mix is off?
Why does my 2000 Chevy Tracker with 20 engine die after it gets hot but restarts OK after cooling fo
vixendrumr
November 8th, 2010 2:42 PM
stepsidechevy
October 22nd, 2010 3:20 PM
dizturbed
January 22nd, 2009 6:08 PM
