04 chevy 2500hd 6.0l no crank
Old Nov 3, 2012 | 3:00 PM
camarozracer8's Avatar
Default 04 chevy 2500hd 6.0l no crank
Somebody please help. I have a 04 chevy 2500hd with a 6.0l in it. I hit the key to start it and all it does is click, I have changed the starter out, changed both batteries, the ignition switch like the dealer said was wrong and still it won't crank. If I jump the starter, it starts but shuts down right away like the ignition switch isn't in the run position. Please help and thanks in advance.
Old Nov 3, 2012 | 3:25 PM
kevinkpk's Avatar
Originally Posted by camarozracer8
Somebody please help. I have a 04 chevy 2500hd with a 6.0l in it. I hit the key to start it and all it does is click, I have changed the starter out, changed both batteries, the ignition switch like the dealer said was wrong and still it won't crank. I don't understand this statement?
If I jump the starter, it starts but shuts down right away like the ignition switch isn't in the run position. Does it die when you remove the jumper cables? Please help and thanks in advance.
My replies in red.
Old Nov 3, 2012 | 4:07 PM
Unhappy
Yea it dies as soon as I take the power away from the solenoid
Old Nov 3, 2012 | 4:50 PM
67Motorcat's Avatar
Have you had the alternator tested?
Also starter circuit relays in the power control center?
Old Nov 3, 2012 | 6:11 PM
The dealer said it was the ignition switch so I changed it out and still won't crank it just clicks
Old Nov 5, 2012 | 4:42 PM
Angry 04 chevy 2500 hd no crank
here is what I have done so far, replaced the starter, replaced ignition switch, both batteries, all the relays under the hood, tested all the fuses, check the voltage at the starter on big terminal,had 12 volts, turn key get 10.74 volts on the ignition stud.
Old Nov 5, 2012 | 5:30 PM
kevinkpk's Avatar
Well, if you have a clamp on amp probe check the current draw with it jump started, and running. How much current draw is there with it running, and jumpered?
Old Nov 5, 2012 | 8:07 PM
MDTAHOE's Avatar
Professional Mechanic
If you truly have the voltage at the starter it should start unless you have a sever voltage drop. Take the battery bolts out look at them very good. Double check all the fuses with a test light. They almost always blow a fuse or 2 when the switch fails. Did The dealer actually look/ test the truck? Do have a DVOM (meter)?
Old Nov 6, 2012 | 4:35 PM
I got the truck running by jumping the starter, however, it still won't start with the key, what could it be
Old Nov 6, 2012 | 8:07 PM
MDTAHOE's Avatar
