04 Chevy Silverado 1500 4x4 Regular Cab
Old Mar 9, 2011 | 12:41 PM
micro368's Avatar
Default 04 Chevy Silverado 1500 4x4 Regular Cab
The other morning I was on my way to work when all of a sudden my truck shut down. I pulled of to the shoulder off the highway (bad spot on highway) I called the old lady to come up and bring some tools that I needed. The truck would turn over but not start. I pulled the alternator took it to the part store and got it tested two different places and passed both times. The battery checks out good. By this time it is rush hour so I decide to get it towed home. My buddy comes over and he has a spark plug tester and I am not getting and spark. I checked the ingtion module thing they all got power. I have double checked all fuses and i dont know what else to look at. It turns over just wont fire up. Any ideas thank you in advance! (the battery light came on after all this happend)
Scott
Old Mar 9, 2011 | 4:07 PM
micro368's Avatar
crankshaft position sensor? Could that be my problem?
Old Mar 9, 2011 | 7:14 PM
RacerX's Avatar
04 is OBDII, so you should have a code.
But no spark? ICM is good? Are you sure? Check ICM for resistance, best way to check. YOu could be getting power to it but not out of it.
Now no spark if ICM is good means the coil is not. I m not sure if 04 has a distributor or coil pack, but if you have coil packs then you dont need an ICM. I know you dont have direct injection.
jonathannelson
Apr 18, 2014 5:28 PM
wallyluap
Sep 21, 2012 2:34 PM
Gerod11
Apr 7, 2012 8:28 AM
2009ChevyRegCabLgBox
Aug 25, 2009 4:00 PM
MrSwapIt
Aug 16, 2007 3:34 AM
