04 silverodo a/c
Old Aug 17, 2009 | 4:35 PM
jcon29's Avatar
Default 04 silverodo a/c
my 04 silverodo ac/ will not come on. i have had the recycle switch changed,and the freon checked. i replaced the control unit in the dash with a 06 modle but this didnt fix it.. in fact it made the air realy hot on the drivers side vents...do i need a 04 control? or do i have a broken wire somewhere?
Old Aug 18, 2009 | 4:31 PM
rruelas's Avatar
is the compressor engaging. try connecting a test light or multimeter to the electrical connector that goes to the a/c clutch. then when you press the a/c button, you should see the light turn on or see some voltage. if you do, then it might be your clutch on your a/c may be defective. Im not sure if you could replace just the clutch without the a/c compressor or if it has to be replace as one assembly.
Old Aug 20, 2009 | 9:58 AM
jcon29's Avatar
the clutch does engage sometimes....i can trick the compresser with the relay.. but the when i use the botton in the dash the clutch only works part of the time mostly when its cooler outside. when it get hoter in the day it will not work at all
davidmtanner
Apr 27, 2013 5:58 PM
zironz
Aug 23, 2012 6:10 PM
samz95bluerodo
Jun 29, 2010 2:54 PM
