Notices
05 silverado, when to change oil?
Old July 30th, 2010, 9:36 AM
  #11
Originally Posted by therewolf
While I have to agree that the oil filter is well placed compared to many, I have to also wonder why the drain bolt is positioned so the oil splashes the exhaust pipes when you drain it.
That'd be because the engineer that designed the oil pan plug layout is in cubical 4, level 3 building A, the engineer that did the exhaust routing is in cubical 23, level 2 building C......
Building C is located in different State by the way....
Old August 2nd, 2010, 10:14 AM
  #12
therewolf's Avatar
Yeah,see, here's where I turn into a molten-hot-oil-splashed conspiracy nut.
Because if the designer of the oil pan had faced the drain plug in a shallow well facing down, instead of back and laterally, the oil would not only drain more efficiently, it wouldn't splash anything on the way out.
in2pro
November 19th, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
February 6th, 2010 1:10 PM
Toby T
March 14th, 2008 5:16 PM
Big D
January 10th, 2008 6:53 PM
digdug
February 4th, 2007 3:08 PM
Quick Reply: 05 silverado, when to change oil?
