06 water pump seeping around pressed neck
My 06 z71 is seeping antifreeze around where the metal neck is pressed into waterpump housing it self. Its not seeping even enough to where it drips on the ground, just kind of runs down the waterpump a little and stays wet where the neck is pressed into the housing. I was thinking about cleaning it, and putting some sort of sealer around the neck first and see if that works before I spend the money to put a new waterpump on it. What do yall think?
Maybe clean it, put some jb welb around it, or some sort of silicone or sealer. What do you think would work?
Yeah it is kind of one of those things you can either get the problem out of your way or put a band aid on it. Personally if you have the money for it just replace it now but if not you can put some sealer on there and will last you good while.
Try FLEX SEAL....it will save you $1000's....
Just keep an eye on it and change out the water pump when you have the funds available.It not to bad of a job to do yourself.
For a while there, I was replacing my W/P so often, I keep the tools
in my truck.
The first one went at 24K, IIRC, and was replaced under warranty.
48K, same thing, but I replaced it myself, and in the process, I
noticed the EOM fan clutch is a real brick. I replaced it with one
about 1/4 the weight, and I've been having a lot less issues...
in my truck.
I just think its shameful on what I've had to do to this truck the past 9 months, only 68k on it now. Had to re route the fuel assembly because I kept getting the service engine light kept coming on, needs water pump, seal in front differential, butt part of my heated seat doesn't work. Ridiculous!
EllieMaysDaddy
March 31st, 2012 2:07 PM
gcpurcell
September 24th, 2007 10:07 AM
