07 5.3 ticking noise
Old Mar 18, 2014 | 9:57 AM
tjf76's Avatar
Default 07 5.3 ticking noise
I have a 2007 Silverado 5.3 with 70k. I has started making noises and feel its lifter chatter. I have no oil pressure issues and no other noises or problems but wanted every ones take on this on. This was recorded from the drivers side wheel area. It makes this sound with engine cold or at normal operating temp.
<!-- m -->http://www.youtube.com/watch?v=YSjv_48F ... e=youtu.be<!-- m -->
Old Mar 18, 2014 | 2:54 PM
bigbadbowtiegirl's Avatar
Most likely its a carbon build up on the lifters and valves. Especially with all the ethanol that is in todays fuels. Pick up a can of seafoam from you local autoparts store. Run some in the engine oil and the fuel. Do an oil change after about 50 miles of running. You can also do an upper engine clean with it by sucking it up in a vacuum line. Instructions are on the can. Hope that helps. (or if your not comfortable have a local shop to a fuel injection service)
Old Mar 18, 2014 | 5:00 PM
tjf76's Avatar
Thanks fo the info! I will try the seafoam out
Old Mar 19, 2014 | 10:02 PM
Official GM Rep
Hey there tjf76,
I'm sorry to hear of this noise that you are experiencing in your Silverado. I would like to take a further look into this for you. If you would like any extra help, please send us a private message referencing this concern. I will be glad to help!
Kristen A.
Chevrolet Customer Care
Old Mar 20, 2014 | 8:51 AM
tjf76's Avatar
To add it the info
The noise I hear takes about 5 seconds after start up before I can hear it.
Old Mar 20, 2014 | 11:10 AM
Does it do it when in gear?
You might also consider getting an automotive stethoscope and check for possible exhaust leak....
Old Mar 20, 2014 | 3:53 PM
tjf76's Avatar
I have not checked if it does it in geaer, will do that tonight.
I was thinking exhaust leak myself.
jharper
Dec 11, 2007 4:13 PM
gulfcoastjoe
Jun 23, 2007 8:48 PM
gulfcoastjoe
Jun 19, 2007 10:23 PM
vfilby
Apr 19, 2007 9:17 PM
sarahsimpson
Jan 25, 2007 2:59 PM
